When inputing the water quality series, the EE_explorer pops up a prompt that is “You truncated the data series,apply changes across all parameters?”, can you tell me the reason? thank you.
The reason for this message is that all the WQ constituents have to have exactly the same timing for a given series. You can see this if you look at WQPSL.INP (mass loading) and WQPLC.INP (concentration) input files. Saying “Yes” doesn’t change all the series, but it changes all the parameters within that series so that they have the same timing.
Thank you very much.
Xiaofeng Chen
