When the wetting/drying option is NOT activated, it seems the wet/dry depth values could affect computation results. Are there guidelines about what are proper values for the wet/dry depths?
Drying depth does not impact results if wetting/drying is turned off. However, the HWET variable is used to shut off boundary conditions if there is too little water.
