I noticed that the file westlake outline.p2d is not part of the folder where it should be located as stated from the video tutorial. Can you please help me on this? Is it possible for you to send me the file or upload it in the website?
Thank you very much and your help will be greatly appreciated.
Hi There, You can make yourself any polygon you like by using the Active Polyline Tool and follow the instruction. After you save to a *.p2d file you just need to copy the first line to the final line to make a closed polygon. Anyway, you can find the attached for your data.
thank you very much xuantinh,
and thank you very much EFDC for uploading the file.
We updated that project so that it now contains the file you requested.
