Dear EFDC,
I want to know about time series plotting. I try to plotting water surface between observation data and model result for calibration. But in #calib_plots emf.file, only observation data graph appear. How to plott its ? i confused to define MMA, define layer and apply default to define/edit calibration plott.
DYAH ARI
dyah2012 wrote: Dear EFDC,
Hi Dyah Ari,
Could you please let us know which EFDC version are you using ? I think it has nothing to do with defining MMA. But you should make sure you have the proper pathname for your data file. In the calibration tools you need to provide, X and Y coordinates , layer , depth , ID , Pathname , parameter, R Avg, Grp Use etc. If you only see observation data graph then the location of your cell where you want to extract the water surface elevation may not be correct. Another thing you should make sure is that in your "Param" column you should input the value as "-1". If you are unsure about what parameter to use then right click on the column of "Param" and you will see Parameter codes. For your convenience I have copied parameter codes here.
Parameter Codes
99 - Disabled
-1 - Water Surface Elevation
0 - Water Depth
1 - Salinity
2 - Temperature
3 - Dye
5# - Toxics (# Class Number, e.g. 51, 50-All Toxics)
6# - Solids (# Class Number, e.g. 61, 60-TSS)
1# Velocities
11 - XY Magnitude 12 - X Component
13 - Y Component 14 - Z Component
15 - XYZ Magnitude 16 - Direction
8## - Water Quality
801 - Cyanobacteria 812 - Labile PON
802 - Diatomaceous Algae 813 - Diss. Org Nitrogen
803 - Green Algae 814 - Ammonium Nitrogen
804 - Refractory POC 815 - Nitrate Nitrogen
805 - Labile POC 816 - Part Biogenic Silica
806 - Dissolved Org Carbon 817 - Dissovled Available Silica
807 - Refractory POP 818 - Chemical Oxygen Demand
808 - Labile POP 819 - Dissolved Oxygen
809 - Diss. Org Phosphorus 820 - Total Active Metals
810 - Total Phosphate 821 - Fecal Coliform
811 - Refractory PON 822 - Macroalgae
Derived Water Quality Parameters
823 - Total Organic Carbon 824 - Total Nitrogen
825 - Total Phosphorus 826 - Chlorophyll a
827 - Total Organic Nitrogen 828 - Total Inorganic Nitrogen
829 - Total Organic Phosphorus 830 - 848 Algae Growth Limits (Not Avail)
849 - Particulate Org Carbon 850 - Particulate Org Phosphorus
851 - Particulate Org Nitrogen 852 - TSS (Inorg + Org)
853 - Total Kjedahl Nitrogen 854 - Total Dissolved Phosphorous
855 - Macroalgae (ug Chl-a/m2)
If it still doesn't solve your problem let us know.
Regards,
