Hi All,I wanted to confirm that the unit for flow in boundary conditions is m3/s. I see the flow unit in the software generated plots is m3/s; meanwhile the manual book says all length related parameters are in m and all time in day. I guess that made me wonder whether flow should be in m3/d. Thanks,Hengchen
Your flow boundary condition values should always be in units of meters per second. If you wanted to use meters per day you can manually edit the conversion factor at the header of each series.
