i want to simulate the baroclinic about the ocean,but i didn’t find a button to open that function.so i want to know if the ee set the baroclinic mode defaultly or can you tell me where the button is,Thank you
i want to simulate the baroclinic about the ocean,but i didn't find a button to open that function.so i want to know if the ee set the baroclinic mode defaultly or can you tell me where the button is,Thank you
Hello Onepiecewx,
To simulate the baroclinic about the ocean you don't need to change anything from the default. There is no button to turn on / off the baroclinic mode in EFDC / EFDC Explorer. You just need to make sure you turn on density. Make your buoyancy factor = 1. I hope it helps.
