Hello, before the learning model ran in days, now I need to set the minute level, what to do,
您好,之前学习模型以天为单位运行,现在我需要设置分钟级别,该怎么办,
Hi kangwu472
If you want to generate a series of numbers up to the hour you can take 5 significant number, if you want to set the minutes level
You need to take at least 7 significant numbers after the decimal. I attached the example below for your reference.
BMHoa
