How is the format of the contents in EFDC’s restart.inp/out represented? I am developing EFDC-related predictive applications and would like to modify the hydrodynamic result files based on actual conditions before continuing the simulation.
Is the restart.out file essentially representing the hydrodynamic results? However, the content of this file has no annotations, and I can’t understand it.
The restart.inp/out file is used for a hot start run in EFDC+. It represents a saved solution from a previous simulation at a specific time step as the initial condition. The initial condition here includes all dynamic conditions, including velocity fields, turbulence, and boundary conditions, exactly as they were at the previous simulation’s last time step.
For I/O operations on such a file, EEMS does not provide variable notations as it does in configuration files like efdc.inp. Modifying the information in the restart file may lead to inconsistencies in the model’s hydrodynamic behavior.
To understand the file structure, we recommend referring to the Fortran subroutine Restart_In(OPT) (starting from line 491) in the restart module (mod_restart.f90), where EFDC+ reads the file.
