After the Corners.inp file did not work, I then tried to import a DXDY / LXLY file set. This appears to import a working cell map. However, all other visualizations in the ViewPlot are not displayed. Why is this an option for an import if it does not work?
We have tested this further and see that if the cell conversion factor is correctly set then this option imports and displays correctly for our examples (note that the cell conversion factor depends on whether the cell centroid coordinates in the LXLY file are in kilometers or meters. The 1000 converts them from km to m. In cases where the LXLY coordinates are already in meters the conversion should be 1.0). Can you please post your examples here so we can see if they are correctly configured and determine if there is a bug or not?
