The depth of my study area is 3-5m, and I divided it into 3 layers. But the simulated layer temperatures are almost the same and are the same as the air temperature. What parameters should I adjust?
In setting the model boundary conditions, a quantitative inflow and a variable temperature series are set upstream. An open boundary is set downstream, given a very small water level. How can I adjust the model so that it can simulate changes in water temperature in each layer.
Huan
