When I choose this option for partitioning, I specify the fPOC in water and sediment as required, along with the Kd values in water and sediment. Although the fPOC values are updated correctly in the efdc.inp file, the ViewPlan mode shows a “0” for the fPOC for each sediment class (ViewPlan->View Initial Conditions->Water by layer-> Toxics->Dropdown options). Appreciate any help with this, thanks!
Hi Adithya,This has been fixed in the upcoming release of EE 10.2 which is coming out later this month.Thank you,Tom
I forgot to mention: EFDC Explorer v 8.4 was used
