Hi
I have encountered difficulties converting the results of cyanobacteria, diatoms, and green algae to CDF format in my netCDF output. I’m seeking suggestions on how to resolve this issue. Any help would be appreciated.
This may be a bug in EE, so we suggest you run the model with NetCDF output directly from EFDC+ rather than converting it. If that doesn’t resolve the issue, please send the model and output and a detailed description or video of the problem to us at support@eemodelingsystem.com
Hi
I can successfully convert water quality to netcdf output, but when I look at results of Cynobacteria, Diatoms and Green algae from .nc file the values are constant for all the cells at 9.9692e+36. However, the results on the model graphical interface seem to be correct. the problem is that results in .nc file are wromg.
P.S. results of other parameters such as T, DO, NOX etc are ok. The problem is just associated with Biota values in netcdf. I sent you an email with further photos you look at
Many thanks
Can you please tell us which version of EEMS you are using? There may be a bug converting your output from the .out files to .nc using this option:
https://eemodelingsystem.atlassian.net/wiki/spaces/EK/pages/2119172097/Export+to+NetCDF+files
There may be a bug with this option which we will investigate.
In the meantime, it would be best if you used this option:
https://eemodelingsystem.atlassian.net/wiki/spaces/EK/pages/240386418/NetCDF+Output
