when run the water quality it shows error
“WQ: READING WQ3DWC.INP - MAIN WATER QUALITY CONTROL FILE
WQ: SOUTH OBC: MISS MATCH BETWEEN NCBS & NWQOBS”,
but i check the NCBS in efdc.inp and NWQOBS in wq3dwc.inp, they are the same, so what should i do?
There’s probably some mismatch in the I/J index between your open boundary cells and the water quality concentration time series(should be in wq3dwc.inp C31~C34) instead of the number of concentration series you checked.
