LPT model crash issue
I am a beginner using EFDC version 8.1.
All other modules such as DYE and TEMPERATURE work properly, but when I use the LPT module, the model runs for a while and then crashes abnormally without any error message.
I have tried changing initial conditions, boundary conditions, hydrodynamics, and timing settings, as well as adjusting every LPT module option one by one, but the model still crashes in the end.
Even when I apply a new grid or greatly simplify the flow, the model only crashes when the LPT module is enabled, and I cannot identify the cause.
Could anyone suggest possible solutions or things I should check to resolve this issue? Thank you!
Hi Julsoon,
The EEMS8.1 version was released a long time ago. It is not supported to fix bugs if they occur. I recommend you try the latest EEMS version (EEMS12.3) by accessing the link below.
Regards,
Duy
