Importing externally generated array data into existing setup
I am using EFDC_Explorer 10.2, and I’ve generated an external array of data e.g., contribution factor derived from multi-class dye simulation using a separate script.
I would like to import this array into the existing model environment for visualization and analysis. However, I am unsure of the correct procedure or supported formats for integrating such externally generated arrays.
Could you please advise on the appropriate method or tools for importing these data into the model system through EFDC_Explorer? If there are specific file formats, templates, or import steps required, I would greatly appreciate any guidance or documentation you can provide.
