Hi!
I downloaded the 2015_09_08 versions of the exe files from your site. I am using EE7.3 (full version, Ver150701). Projects I’m working on and a new test started from sratch give following error message:
INPUT ECHO NCARD = 46B
10.00000 0.2500000 0.6000000 7.0000000E-02 4.9999999E-03
1.000000 916.0000 0 9.9999998E-03 0.0000000E+00
READ ERROR FROM FILE EFDC.INP ON CARD 46B
The line in efdc.inp is
C46B HWI ALBEDO BETAI GAMMAI ICETHMN RHOI ISRHEVAP RISEVEL
10 .25 .6 .07 .005 916 0 .01
The model seems to require an extra parameter after RISEVEL. Could you explain the role of this parameter.
Best wishes,
Heimo
Hi Heimo, you need to also update your EE7.3 at the same time. The latest version of the exe is release 150921 which runs with EFDC_DSI_073_150908. They are downloadable from here: EFDC_Explorer Modeling System – EE Modeling System
