I noted that M typ# in vege.inp need to match with the number of polygon file.But I found it did not the same in some sample application,as Lake Washionton.The numbers existed in vege,inp do not show in dxdy.inp.
So I want to konw how to use vege.inp file correctly when I run the model by code,not the EEMS.Anybody can help me? Thanks!
Hi 1275462698
- I do not know which EEMS version did you use, but EEMS10.3.3 still displays the numbers existed in vege,inp do not show in dxdy.inp. see two images attached
- when you run the model by code need to match Type# in vege.inp file with VEG-TYPE column in dxdy.inp file
I run the efdc model by these files shown in the picture,not by the EEMS.
I have match the class number In the vege.inp and dxdy.inp,and compared the difference the model result whether vege.inp contained.I found that the existence of vegetation only influence a little difference on velocity,and showed no difference on water level.So I wonder konw if I set the file wrong.
I will check it later,thank you again.
I found vegser.inp could adjust the parameters of vege.inp,but i did not found that in the manules.Could you send me that ?
thanks!
