How to input multiple model files in MPI in EFDC+
I have some questiones about the MPI used in EFDC+ by code file, which is whether I should input two model files at the same time to run, or enter two model files in turn to run,if the former,it means that I need to download several EFDC+ model codes?
I’m look forward your reply.
If you are running on separate machines then you will need to share the model and the EFDC+ exe across those machines. You can refer to guidance here:
https://eemodelingsystem.atlassian.net/wiki/spaces/EK/pages/609583125/MPI+on+a+Single+Machine
