GetEFDC seems to have hit a snag for me. Below is the output from the crash. I’m not sure if the crash is because it is looking for the MAPPGNS.INP (which EFDC Explorer didn’t create). Below are the error messages and input files.
Thanks for the help
Error message
C:ProjectsModelEFDCWQModel-Copy>GETEFDC GETEFDC.INP
*** GetEFDC IS DEVELOPED BY DYNAMIC SOLUTIONS-INTERNATIONAL IN HANOI ***
*** IT IS USED TO: ***
*** EXTRACT EFDC OUTPUT FILES (BINARY) FOR LAYER/TIMESERIES DATA ***
*** THE OPTIONS FOR EXTRACTION DATA IS IN THE FILE GETEFDC.INP ***
*** THEREFORE PLEASE EDIT THIS FILE ACCORDING TO YOUR NEED FIRST ***
*** THEN RUN THIS PROGRAM BY ENTERING THE FOLLOWING COMMAND: ***
*** ./getefdc.x getefdc.inp ***
*** BUFFER: GETEFDC.INP
*** READING GETEFDC.INP FILE
forrtl: severe (24): end-of-file during read, unit 22, file C:ProjectsModelEFDCWQModel-CopyGETEFDC.INP
Image PC Routine Line Source
GetEFDC.exe 00F66680 Unknown Unknown Unknown
GetEFDC.exe 00F34FCF Unknown Unknown Unknown
GetEFDC.exe 00F21467 Unknown Unknown Unknown
GetEFDC.exe 00F207AA Unknown Unknown Unknown
GetEFDC.exe 00F10984 Unknown Unknown Unknown
GetEFDC.exe 00EF2CA9 Unknown Unknown Unknown
GetEFDC.exe 00F70DD3 Unknown Unknown Unknown
GetEFDC.exe 00F50B15 Unknown Unknown Unknown
kernel32.dll 759A336A Unknown Unknown Unknown
ntdll.dll 77769902 Unknown Unknown Unknown
ntdll.dll 777698D5 Unknown Unknown Unknown
Input file
** COMMENT LINES START WITH ""
** GETEFDC VER. 20150612 IS USED TO:
** EXTRACT EFDC BINARY FILES *.OUT TO ASCII FILES FOR:
** 1.TIME SERIES AT SOME LOCATIONS DETERMINED BY (I,J) OR (X,Y)
** 2.TECPLOT OF ONE LAYER (K>=0) AT OME SPECIFIC SNAPSHOT
** 3.ARRAYS OF DATA
** OBLIGATORY INPUT FILES:
** 0.GETEFDC.INP: THIS FILE
** 1.EFDC.INP
** 2.LXLY.INP
** 3.DXDY.INP
** 4.CELL.INP
** 5.CORNERS.INP
** 6.MAPPGNS.INP
** THE FOLLOWING BINARY FILES WILL BE READ ACCORDING TO SELECTED ITEMS
** 1.EE_WS.OUT
** 2.EE_VEL.OUT
** 3.EE_WC.OUT
** 4.EE_WQ.OUT
** OUPUT OF GETEFDC IS STORED IN RESULT FOLDER
** THE FULL PATH OF INP FILES is determined by the file efdc.inp:
C:ProjectsModelEFDCWQModel-Copyefdc.inp
** OPTIONS FOR OUTPUT:
** LAYK = K>0: DATA AT LAYER NUMBER K TO BE EXPORTED AT TIME=JULTIME
** 0: DEPTH-AVERAGED DATA IS EXPORTED
** -1: Get High Frequency output FOR CELLS
** -2: Extract data for Time series at a height above bed (m)
** -3: LOAD TMP.DAT AND EXPORT TECPLOT
** ZOPT = 1: FOR THE DEPTH UNDER WATER SURFACE IF LAYK=-2
** 2: FOR THE HEIGHT ABOVE BOTTOM IF LAYK=-2
** NDRIFTER : N1:N2 A SET OF DRIFTER TO GET (X,Y,Z)
** JULTIME : JULIAN TIME FOR SELECTED LAYER
** > MAXTIME THEN JULTIME=MAXTIME
** 0 DATA FOR ALL SNAPSHOT
** NLOC : NUMBER OF CELLS TO EXTRACT TIMESERIES
** ROTA = 1: (U,V) AT CELL CENTER ROTATED TO TRUE EAST AND TRUE NORTH
** 0: (U,V) AT CELL FACES WITHOUT ROTATION
** INDEX = 1: (I,J) OF CELLS ARE GIVEN
** 0: (X,Y) OF CELLS ARE GIVEN
** VPROF = 1: EXPORT VERTICAL PROFILE
** = 0: NO EXPORTATION
** TECPLOT = 1: EXPORT DATA FOR TECPLOT
** = 0: NO TECPLOT EXPORTATION
** LAYK JULTIME NLOC ROTA INDEX VPROF TECPLOT ZOPT NDRIFTER
0 0 1 0 1 1 0 0 1:5
** I/X : I Index or X of cell
** J/Y : J Index or Y of cell
** ZINT : THE DEPTH UNDER WS OR HEIGHT ABOVE BED (m)
** FOR TIME SERIES EXTRACTION IF LAYK=-2
** I/X J/Y ZINT(m)
** 396620.099 2929719.272 0.5
** 393606.368 2921837.206 0.7
8 8 0.5
