I have a few questions about the use of the Fortran data extraction utility for EE7.2. Does the Fortran executable have be in the same folder as the getefdc.inp input file? Also, I’ve followed the guidance given in the example getefdc.inp files, specified the paths to the files pertaining to the models I want to extract data from, and have run the utility. No output appears anywhere, and the Windows commandline window only flashes and then closes. Am I doing something incorrectly? Is there somewhere a set of step-by-step instructions for using this utility correctly?
David
Hello David,
I have created a step by step instructions for using the GetEFDC program. Hopefully, it will help solve your problem. If you just double click the file, then the results are not extracted.
I have attached the document along. Please let me know if it still doesn’t solve your problem.
Janesh Devkota Attached files getefdc_guide_2015-06-03.pdf (142.6 KB)
