If I am going to build a dam and the plant material is not removed from the area,
How Do I water quality model of flooded biomass?
How load could be estimated?
How could estimate degradation rates?
How simulate matter organic load within the reservoir?
How estimate the release?
Can I handle this load as detritus?
Best regards
You can probably reflect this through the sediment kinetics – not the sediment diagenesis model. You will need to do some research to determine the correct parameters. Our recommended approach is to use a specified flux both spatially and temporally.
I understand, Thank you so much for responding so quickly. It really helped me.
