What is the algorithm/method used for computing evaporation internally by EE in ASER.inp?
Rumana
dumby08 wrote: What is the algorithm/method used for computing evaporation internally by EE in ASER.inp?
Rumana
Hi Rumana,
In EFDC Evaporation is calculated as follows. FIrst of all wind speed function is calculated as
FW=9.2+0.46*WINDST(L)**2;and the the evaporation is calculated as
RE=FW*(SVPW-VPA(L));where SVPW = saturation vapor pressure in mb based upon the water surface temprature
WINDST = wind speed at 10 metres over cell surface (m/s)
VPA = vapor pressure of air at near surface air temperature (mb).
The more details about evaporation and other heat related parameters can be found on CALHEAT.for subroutine. I hope this helps.
Thanks a lot.
I must say you are a genius in EFDC.
Rumana
Thank you for your kind words. I have a lot more to learn in EFDC. Glad I could help you.
