exoexo12386
Please check the reasonableness of the initial temperature condition, and the reasonableness of the temperature data in the input series, and also check whether your time step is set reasonable.
BMHoa
I don’t think flow/water level boundaries are possible if the water temperature is below 0 degrees C.
Please check the flow value or water level at the same time the water temperature is less than 0.
BMHoa
Are you still having problems running the model? if so please email the original model to bmhoa@dsi.llc and I will look into it.
BMHoa
