Usually we change the inflow and outflow of the reservoir to control the water level change, but now I only have the data of the water level change, can I use EFDC to simulate the water quality change of the reservoir at this water level? Thank you
Thank you very much for your question.
Can you provide some clarification? You say that you “have only the data of the water level change.” Is this data related to the water level at the inflow or outflow points, or does it pertain to the reservoir’s water level?
I assume your plan is to first successfully conduct a hydrodynamic model and then build a water quality model based on the hydrodynamic model. Is that correct?
