There was no problem running other modules before. After loading the algae, the floating point division by zero phenomenon occurred. I checked that the input conditions and initial conditions are not discontinuous. How should I solve this situation?
Hi 1632209860,
Welcome you to our community and thank you for your question!
Could you please provide us the details of EE version that you used and any captured images for your issue?
Trang
hi nqtrang,
I recently encountered a new problem. When I tried to calculate the water age of a long series, I could only calculate it to the 364th day and could not continue. The error prompt is Display floating point number as zero.
Hi 1632209860,
Thank you for your question!
It’s hard for me to determine the problem with this captured image. It would be better if you send me the model you ran without output, then I can help you to check all the model input as well as parameter setting.
Trang
