I have example files for Mhk Modeling.But It can’t running - “JPG” Errorswhat is problem?
Can you zip and attach your model input files?
Sorry. I forgot uploaded the files. and Uploaded Zip files.Thanks
We had a look at your model and found there are some inconsistencies related to the setting of vegetation classes, even though they are not assigned in the model. You can see the density is zero for example. If you turn off vegetation the model runs. You can also configure them correctly and assign to the model and it will run as attached.
